Protecting bare metal
Car: 1987 IROC
Engine: 383SR
This winter I'm planning on starting some body work on my car, and plan to media blast the engine bay. How do I protect the bare metal from flash rusting before I prime it with a self etching primer? OR am I suppose to use the self etching primer immediately?
Thanks guys
Thanks guys
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Re: Protecting bare metal
I remember reading this Magazine article...
They put bare metal stripes on this Nova, looked pretty wild. They kinda grained the steel by directional sanding, then sealed it with this stuff. I have the article around here somewhere, I'll find it. Thought that may not be what your looking for.
I would say though, if you planning one a conventional prime/paint/clear operation. I would just prime it good now if your conditions are right (temp,humidity). Might even do the base coat too if your going that rout. Beyond that I dont know what will provent surface rust without applying some kind of sealant.
Max,
Max,
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Etch primer (on bare metal spots only), then an epoxy primer (covering everything) would be ideal. No rust issues whatsoever if applied properly, and you can just clean it off and shoot it when its time for painting. This is the order it should be done in, from first to last:
- CLEAN Bare metal
- Metal conditioner/Etch primer
- Epoxy primer
- Primer Surfacer
- Sealer
- Base
- Clear
- CLEAN Bare metal
- Epoxy primer
- Primer Surfacer
- Sealer
- Base
- Clear
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Max,
Max,
i saw that car are a car show that was wicked
RedLeader289
05-28-2019 01:47 PM
sjorgens
10-01-2015 07:54 PM
