Mounting tabs for Aero wing spolier???
Re: Mounting tabs for Aero wing spolier???
I'm curious too
Also if anyone has a close-up picture of what the tabs look like, I may be able to make something that would work.
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
sorry guys, as far as I know noone makes the factory style tabs for factory spoilers.If you have an aftermarket fiberglass spoiler they usually come with
tabs to mount them to your hatch.
There was another member here that made his own with some sheet metal
for his 4th gen wing but can't remember who!
Actually,If I remember correctly,it was one of the moderators here!
Still can't remember who it was.
Try a search for (cheesy clips on 4th gen wing)
Don't know if that will help,but will give you an idea what to search for
(I hope)
(I hope)
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
browse around http://cliphouse.com/ and look for something similar or the same. Go by what they look like, if anyones knows.
Car: 88 gta
Engine: 350 tpi
Whenever I see a wing in a junk yard I grab any clips that aren't cracked, I you will usually grab one or to at a time this way, otherwise you are screwed, sorry...
I found this doing a search and am pretty sure I can fab something up to work if i can't find a couple of them. It just looks like a piece of steel with a slot in it.
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
I've called around wrecking yards here in Ontario and I've yet to find one that actually has any third gens in their lots Was trying to see if I could find a fiberglass one from a 92ish T/A - i think those were fiberglass.
It's showing up now.
Someone mentioned before that Hawks sells a "kit" that comes with thier fiberglass wings that has clips for attaching to the glass frame.
Can anyone verify if it is metal or plastic?
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
All I have seen is the metal tabs along the metal edge around the rear hatch. I have never seen them where you can attach them along the hatch. You would have to locate a hatch that has the clips already in place, sans wing.
I have a wing available if anyone is interested.
JB.
JB.
Car: 1987 Firebird
Engine: 355
The pic posted is the metal tab that is welded to that hatch. Thats not the clip. The clip is a small, white serated looking thing.
I gave up on my wrap around spoiler and hatch option because of the clips.
Fyrstorm, i know a couple junkyards around here with thirdgens. Just none of them know what they have. You can try Paradise Alley, but they charge an arm, a leg, and your firstborn.
And,yes I can verify the clips are metal for the hawks 4th gen wing.
give me a reminder if you don't see a pic before noon.
I actually think you'd be surprised at what actually holds these things onto the car.Not much more than a tab from a soda can.
Car: 86 Trans Am
I figured when I get to that stage of my car I'll go to lowes and get a strip of still and bend it at a angle and drill / cut a "catch" into it like the above picture to hold the spoiler.....then spot weld it to the frame....no biggie
IROCZDAVE (88-L98)
09-02-2015 09:49 AM
