t-tops squeaking
Car: 87 Trans Am
Engine: V8 305 TPI
t-tops squeaking
its really annoying when I'm driving and the t-tops squeak. any easy ways to fix this? do I just need new weatherstripping?
Re: t-tops squeaking
Do you mean that the T-tops shift and squeak while you are moving? Maybe you could use some Silicone spray to moisten the rubber, to reduce the squeaking, but not a permanent fix. Good luck.
1 Post
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
You can try adjust the t-tops, maybe lower where the pins go in a little.
You probably need weld in subframe connectors. The body is twisting make them squeak. I can highly recommend the ones from Global West; I've put them on a couple of cars and they work great.
I had the same problem and it fixed it.
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
lo-tec, i did a quick google search and global west sfc because im in the market for a good set and it appears they only have bolt ons, ive heard that weld ons are the way to go?
1 Post
Weld-ons are the only way to go. Welded front and rear and stitch welded down the sides.
Theirs are weld on.
http://www.globalwest.net/1982-02_Ca...lobal_West.htm
Theirs are weld on.
I was going to suggest SFC's.. I will either tottaly eliminate the squeaking , or almost, at least. Weld in is the only way to go, the holes in the bolt on ones will eventually wallow out, and the weld-in's will stiffen the car more than the bolt-is will. You will be happier with the way the car handles and feels on the road. Not so much "Cowl-shimmy".
Car: 87 Trans Am
Engine: V8 305 TPI
im a little confused. im pretty sure it is the bolt that is squeaking. and what exactly are weld-ons? where do they go?
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
Thirdgen89GTA
11-26-2015 11:04 PM
