Bolt Specs -- Torque Arm
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
I need the bolt specs for the top bolt on the brace that holds the torque arm to the transmission. The bottom two bolts go through the transmission and the top one screws directly into the transmission (It's the red dot).
I believe the hole in the transmission is stripped. I'd first like to run a tap through it to see if that will work, which it probably wont, but who knows.
Thanks.
Greg
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Bolt Specs -- Torque Arm
You put this in the BODY forum?? How about suspension, or heck, even transmission??
Just use the two bolts then. I'm guessing the T5 housing is aluminum, so a tap will not work too well. I'm guessing it's an M8 coarse bolt right?
Engine: 400
Useless.
Thanks.
ambainb
04-25-2016 09:21 PM
