door pins and weatherstripping???
Car: 92' RS 25Th Anniversary
Engine: 305ci TBI
Axle/Gears: 10 bolt limited slip.
with alot of work done, its finally time to tackle my 50lb sagging door problem. Any good tips before I get into this????
Also, I noticed a foggy windshield while it was sitting in the rain yesterday. So, guess what, I think its time for new seals, But I have the same problem as trying to find side skirts, WHERE DO I GO?????
Car: 1987 Camaro Base model
Engine: 2.8L V6
Transmission: 200C Automatic
Axle/Gears: Stock
Re: door pins and weatherstripping???
Ok I am about to go throught the same thing with the door pins and i have found a website with all the tools and parts that you need for it.
http://www.top-downsolutions.com/pro...products_id=38 I have pictures that i took today just e mail me and i can send them to you
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Each kit will repair one ThirdGen (1982-92) F-Body door.
Door Hinge Repair Kit for 1982-92 F-Bodies (Non- Greasable)
[200370]
$74.00
Yikes!!!!!!!!!
http://www.top-downsolutions.com/pro...c639e334294f8e
by DONALD DANIEL II
Date Added: Wednesday 13 August, 2008
I am very displeased with TDS. I was dupped into thinking that this kit was complete. It is not complete! The Lower Detent Pin and Roller Kit is needed to make the Door Hinge Repair Kit able to ..." regain the original structural integrity"... of a Third Gen F-Body door. I bought Greaseable type, 2 of them--BIG MISTAKE. For $96.00 TDS should include the Lower Detent Pin and Roller Kit which is more liket than not worn out. The lower hinge pin on my 25yr old F-Body is resuabale where as the Lowe Detend Pin is not. I could have gone a different rout, still bought the Detent Pins from TDS and saved $50.00!!
[200370]
$74.00
Yikes!!!!!!!!!
by DONALD DANIEL II
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
i used the TDS kit and was very pleased.it does not include the roller and pin as stated but is a very nice kit IMO.my doors work like new now.
as far as weatherstripping go with GM .pricey but worth it.
good luck Mike
good luck Mike
Hey guys,
Im going through the exact same thing. Need a weather strip kit and new pins. Is there any other alternative to these rather pricey kits?
Hotrodboba400
12-10-2019 07:07 PM
gta892000
09-16-2015 12:37 AM
