fibre glass front ends
Car: 88 iroc
Transmission: 700r
i found one its allone piece exc shape butt its 4,in longer than stock wtf does that mean and what needs to be done to make it work on a 88 iroc with a pinned hood
1 Post
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: fibre glass front ends
ok im not an expert but if i had to guess id say if its just the front bumper cover id say your good and 4 inches longer just means it would stick out further but if its a complete front clip my guess would be the 4 inches long is for a stretched front end in a heavily modified drag car, again thats just my guess
1 Post
Car: 1987 Trans Am
Engine: 355
Transmission: t56
I think the fenders are 4 inches longer, your front end would need to be modified to accommodate the extra length. try running a search to see if you can find out some better info.
Car: 87 GTA
Yep....If I recall correctly, the extra 4" is between the wheel arches & the back. Meaning, they'll sit 4" too far forward, but you could always trim them to fit a stock size.
Car: 88 iroc
Transmission: 700r
the 4in,s is behind the front wheel to door opening i could trim not a big deal more worried about hood and cuttin in the lights
1 Post
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Those are very much made as just a cover for a drag car, so it'll be very thin and not have stock mounting locations.
Terrell351
06-13-2021 01:13 PM
