Is primer a good idea???
So im going to get started on restortion, and first on the list is to paint my car. im taking the cheap route, flat black/primer.
Is this a good "temporary" paint job??
Ive seen a few third gens and they didnt look to bad at all. Does anyone have any pictures?? Or tips on going about the whole proccess?
Very much appreciated
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Is primer a good idea???
I Heard Primer Holds In Water / Moisture. Im sure someone will chime in.
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
my car has been in primer for the last three years i can tell you unless you plan on painting shortly after its a bad idea i'm always fighting surface rust i have to re sand it down and primer again, in my opinion i would do your paint last we painted my buddy's car the worked on it and ended up repainting it because of it getting some scratches in it, or it'll be like mine and you get so busy with everything else it never gets painted
Car: 95 Z28, 92 Camarobird
Engine: 410 rearwheel hp LT1, TBI 305
Transmission: 4L60E, 700R4
Axle/Gears: 4.11's, Whatever BS GM put in it
The only thing that would prevent the rusting is actual paint. We just went over a lengthy thread last week about the best way to acheive the flat look on your car.
i think so sorry im not real sure all i can tell you is to maybe put a coat of clear on it for now it'll act like a sealer, just hope you have better luck with yours then i did mine
im considering just keeping the primer until i can save for a good paint job.
but that is true about the scratching. my "restoration" isnt much though. just wanna through some cragar drag wheels on there a loud exhaust and give it a tilt so its lower in the front and higher in the back. trying to get it aggressive looking.
But back to the primer, does it look smooth? is there anyway to do that, maybe wet sanding?
mainly the reason we got scratches in his is because some of the guys helping werent very careful and with the paint still kind of soft well you get the idea my car is in the garage about 90% of the time and i still get some about every 3 months and its not a very smooth look wet sanding didnt help me any with that
1 Post
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Why don't you just throw some cheap paint at it after priming it? I have seen single stage paint from PPG for around $80 per gallon. Its not the best paint, but it would prevent all the problems with just having primer on the car.
that might be a good idea, im planning in general to get a cheapo paint job from macco or earls schieb. im only 16 so cash is way low. at the most ill spend 1000$ on the job.
1 Post
Car: 1987 Trans Am
Engine: 355
Transmission: t56
certain primers will be fine, for example if you have your car to bare metal - put an etching primer on it, this seals the metal from water/other elements. then topcoat it with a regular urethane primer.
another option would be epoxy primer which seals the metal and you can put your basecoat right on it too.
Car: 1985 Camaro Iroc-Z/Z28
Axle/Gears: 9 bolt borg werner, gears unknown
I'm 26 and cash is way low to me too!
I plan to look into a local paint shop that doesn't charge too much and one of their branches did decent work; rather have decent than crap work.
But as everyone seems to shime in the work from Maaco or shrieb is a toss up at times depending on the location.
haha i like the way eeeeefirebird thinks haha.
but yea, i think ima get one of maacos best packages and find out exactly whos gonna paint my car, then give them some extra money(under the table) to do an extra good job.
Someone mentioned epoxy primer above. That is the way to go if leaving it bare for a while......it will seal it and you can even drive it around in the rain with no problems. Etching primer will not seal the metal though, it is still porous. If you go the epoxy route though, talk with the maufacturer of the paint as some brands need to go over bare metal.
Car: 88 GTA "Cocaine"
Engine: 350 tpi
paint it with cheap implement enamel $22 a gallon
put it on thick with a bunch of hardener
when you are ready block it down with 400 and shot it with urethane clear
someone will tell you it cant be done but ask if they have ever done it before and you will not get a yes or no
just reasons why it wont work
I can show you pics of my work and yes
It works!!!
It works!!!
1 Post
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
to rattle can your car. as far as primer goes, dont skimp on this stuff, its what makes the entire job, ppg k38, the ABSOLUTE BEST YOU CAN BUY,dont buy anything else. spray everything that you plan to paint with it, around 4 coats,then take a can of cheapo flat black paint and mist some over the entire car, lighty, only enough to see its there, then you get your sanding block, sand down every area that has been primered, after you are done sanding, if you still see any misted spray bomb spots, fill them in with two part buddy putty, dont use the one part bondo stuff (or anything that says bondo for that matter) after you get all your low spots filled and your high spots knocked down, put 2 more coats of primer over everything again, the wet sand it with 400 grit and then 600, now your ready for base
Car: 84 z28
Engine: 355
Transmission: TH350
you can paint directly over etching primer, ive done it before. you only do that when you have absolutley no body work needed, example freshly sand blasted fender, its somewhat tougher to cover though when you go to paint it, when ever i do that i put a coat of sealer over everthing
1 Post
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Car: 84 z28
Engine: 355
Transmission: TH350
im not afraid of painting over it, if primer surfacer will stick to it, then base and clear will, its just that it usually comes out a different color than if you put sealer on it, but if the whole car is sprayed with ething primer then there is no problem
CarGuyDennis
137
12-06-2016 11:02 PM
mdtoren
08-16-2015 05:45 PM
