head light doesnt always pop up
sometimes it does its maybe a 50/50 chance..
but anytime i raise or lower them it makes a
kachunk kachunk kachunk kachunk sound for about 5-10 seconds
when it doesnt come all the way up it goes maube 1/4 the way up and its REALLY easy to lift not like its stuck or anything...
im sure its common but how do i fix
Car: 86 WS6 Firebird
Engine: 355
Axle/Gears: 2.73 open
Re: head light doesnt always pop up
mine does the exact same thing on my left headlight it is the headlight motor the plastic gear that turns to raise and lower the headlight has broken teeth you have to replace the headlight motor to fix it.
1 Post
Car: 89 firebird
you should check out this site, it says how to fix some of them
http://www.bfranker.badz28.com/headlightfix/index.htm
(its at the bottom)
it works great for me
(its at the bottom)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
sounds to me like you need a rebuild kit for the motors.There are 3 bushings inside the motor assembly that are notorious for crumbling apart and causing the headlight not to work properly.He sells a nice rebuild kit with good instructions.I bought the kit for my car a few years ago,and haven't had a problem since.
Car: 2002 Camaro
Engine: :(
Mine did that.....I converted my plastic gears to all metal ones, It works great and makes less noise.
I bought my gear of ebay....it was not cheap becasue I bought the main gear, then had to buy another that the seller had on his website. I am happy though.
ok so the gear looked fine but TONS of bustup something in there
i will guess its the pucks..
so i put in some hose... and now nowthing works at alll
scroll down to the bottom of this page. This is where i learned how to fix my headlight motor. I rebuilt both and they worked great now. they dont pop up when i turn on the parking lights and they use to run even have the were already down. No more hehehe
You probably took the actuator out of the headlight motors frame right? There's these little rectangular things that have to be touching the actuator. This is what gives it power. They go into these little sockets on the side of the actuator and behind them are supposed to be springs. There are two springs, one for each side. They are a big *** pain to get back into the holes and keep them there while you slip the actuator back in. maybe this your problem?
OHHHHH.......
i only seen 1 spring.. got a great technique to get them in..... that would be the problem..
but someone bought the car today for 1500 haha..
Car: 89 Formula Firebird
Transmission: 5 speed manual
Axle/Gears: 3.45
I have a question, my head lights on my 89 both open up perfect. They just won't close, I have to manualy lower them. Is this still a gear problem? Does the motor work in foward and reverse, or does the motor move in only one direction and continually rotate the gear? Just wondering if I have a motor issue or just need to use the rebuild kit and replace the gears?
Lon
Axle/Gears: 3.45
Thanks for the help. I'll give it a try and see what happens. Tail light fuse is good, so I'm going to try your tip on the module, either way think I will look for a new module anyway.
Thank again
Thank again
ambainb
04-25-2016 09:21 PM
