Rolling my fenders
Car: 1988 Pontiac firebird
Engine: built 350
Transmission: 700r4 built up to 600hp
Axle/Gears: stock for now
Rolling my fenders
How should i go about this? Can i do it without buying a fender rolling tool?
Car: 2004 Silverado SS
Engine: 6.0L LQ9
Axle/Gears: 4.10 AWD
Re: Rolling my fenders
a BFH would work, or a baseball bat. but safest bet would be the proper tool.
1 Post
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
i am interested in rolling my fenders too, say u use a baseball bat. u just put it between the fender and tire then just roll forward? where would you get the tool?
Engine: built 350
Car: 87 GTA
While simply usig the baseball is usually OK, I would suggest considering to cut the inner lip...little cutsever few inches, then using the baseball bat. That way, your not trying to roll the lip in 1 long piece, but rather in short sections.
This thread is crackin' me up.
Baseball bat... hehe
I need pics to either make the image that much more hilarious that I have in my mind or make it so I can understand what the heck the process is.
1 Post
Engine: 383
ohhhhh, thats how you do it, for some reason i was thinking that the baseball bat was slightly larger than the distance from the tire to the fender so you wedge it in then roll the car forward so it dragged the bat between the lire and fender, which rolled the inner fender in. lol
Car: 87 GTA
Well...sorta.
Put the bat in at an angle, pressing up on the lip. Have a friend "drive" , really just easing on/off the brake, and let the idle creep the car forward, him holding the pedal, but letting the car GENTLY move forward. It'll cause the bat to roll the inner lip up, if the person holding the bat keeps pressre right, holding the bat at the angle they need to push up on the lip.
I still think trimming the inside of the lip makes it easier, to move it in short sections, rather than in one long section.
Car: 87 GTA
Yep. Maybe 1/4" deep? I haven't looked in a long time, so I forget exactly how tall that lip is.
Cut just enough, but not enough that you can see the cut from outside the car.
I had mine done at a wheel/tire shop with a roller similar to those sold by Eastwood. Still flaked the paint on the lip, but Im having mine repainted eventually anyway.
If you're careful you'll get just as good a result with a baseball bat. Just don't try to do the entire job in one roll
Ken
Ken
darwinprice
17
10-11-2015 11:51 PM
