how to remove GTA hood grills?
Old 07-07-2008 | 10:41 PM
davr89's Avatar
Car: 2004 Silverado SS
Engine: 6.0L LQ9
Axle/Gears: 4.10 AWD
is there any possible way to remove the grills on the hood of a 88 gta without ruining them or the hood?
i want to paint behind the grills black.
Old 07-07-2008 | 10:48 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: how to remove GTA hood grills?
do a search I had a thread for this same question a while ago, for the front ones theres 4 bolts each, the back ones theres clips.
Old 07-07-2008 | 10:58 PM
davr89's Avatar
Engine: 6.0L LQ9
i did a search and didnt see anything
Old 07-07-2008 | 11:05 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
The front two grills, theres 4 "bolts" but they arent really bolts. You need an 11mm socket (deep) and it should come off easily. Its one of those retainers that have a hex head on it, so you should loosen, and like 1 or 2 turns later they come off. Theres 2 on the front of each grill, 4 in total, then the front of the grill lifts up, and pulls out.
For the rears, theres two clips that run along the INSIDE of the vent. You will need a long flat head screwdriver, Theres 2 clips for each vent, they are fairly large, dont mistake the plastic honeycomb clips for the larger ones.
You may also need to remove the "foam" around the vents that seals them and keeps water out, to be able to reach the clips.
Frozer!!!
01-19-2024 05:55 PM
Wife'sCar
08-22-2015 02:46 PM
mustangman65_79
08-12-2015 07:39 AM
bryan623
08-10-2015 12:33 PM
3rdgenparts
08-08-2015 08:09 PM
Quick Reply: how to remove GTA hood grills?
