windshield molding
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
windshield molding
i am just about ready to shoot some primer and i was wondering if you guys think it is worth it to pull the windshield seal. i did a search and found that it can be done, but is it worth the time, money and effort. i am not changing the color and the paint is in good condition but i dont want it to look like crap when i am done especialy since i have removed everything else that i can from the car except that and the little rain gaurd above the doors.
oh ya, how do you remove that little rain gaurd? i tried to pry it off and it started to bend before coming off. i think it is just held on by double sided tape. i dont want to pry it off and end up with a mangled mess...unless they are cheap!! any help would be great!!
Car: 87' Iroc
Re: windshield molding
maybe smear a very thin coat of grease on the windshield seal so that once the primer is dried you can just take a towel and wipe the grease off.
Car: '82 Z28
Sorry but that is dumb. That would be the last thing I'd want to get near a surface that needs to be painted and the last thing I'd want on fresh primer.
irockid, that moulding is probably glued in with the windshield so it might come out in chunks leaving some behind. Mine started to come out good but ended up having the top half of the moulding ripping off from the part that sticks down by the glass. I was planning on getting a new windshield put in anyway so got out what I could. Tape it off good if you don't want to pull it out, did that the 1st time I painted my car.
Haven't delt with the rain guards so no help there.
Car: 1986 IROC
Axle/Gears: ???
dealerships still carry this item i believe i bought mine for 45$ just pull it of and at the end you will love how it looks
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
To remove the rainguards along the top of the side windows, you need to remove the weatherstripping. The guards are screwed into the body in the weatherstripping grove- I plan to remove mine when I strip the car down for paint...
Car: 88 iroc camaro
Axle/Gears: stock
just remove the rain gaurd all together? dont replace it? does any one have any pics or any other information about this free mod? i think it will look clean but will it change the way water moves around the car when driving in the rain in a negitive way?
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
i am doing my car soon and was wondering if i take the windshield stripping out and buy one new will i be able to put a new one in myself or do the windshield people have special tools
I pulled the windshield molding off with the windsheild still installed and I ended up breaking the windsheild. I did wish I had removed the windshield the first time and saved the 180.00 for a new windsheild.
Car: 88 iroc camaro
Axle/Gears: stock
i do appreciate all the idvice and ideas but i came up with idea myself. i am going to take a long piece of 14 gauge wire and put it under the windshield molding as far back as possible. that will leave a 1/4 inch gap to get paint under. i dont expect to paint the whole area under the molding but when i remove the wire there will be no paint line showing.
1Aauto
Sponsored Vendors
24
03-27-2018 12:59 PM
Bohemian
08-15-2017 06:11 PM
Saxondale
Exterior Parts Wanted
09-07-2015 07:11 PM
Saxondale
Exterior Parts for Sale
09-07-2015 12:40 PM
