Removing Hatch Glass From Metal Hatch
Car: 1988 IROC-Z
Im trying to separate my hatch glass from the actual metal hatch, and im having problems with it. All of the nuts and bolts are off, but I think its urethaned together....How do I get it apart?
By the way, I searched and didnt come up with anything.
Re: Removing Hatch Glass From Metal Hatch
I'd be interested to know the answer to this as well -- I'll be swapping my glass for one with a defrost grid somewhere down the road.
Car: 83 Z28 Camaro
Transmission: 5 Speed manual
i think im going to just get a new hatchback for mine... my back window is shot completely who ever had it with me put some kind of crap on it... now i cannot get it off the window.. and the door is off aligned and the stock spoiler is chipped but yea have fun trying to find the answer.
Car: 1984 Camaro Z28
Axle/Gears: 4th gen auburn 3.42 disc
just look around in some posts bro, do a search first.
here check out my thread, its in there...
https://www.thirdgen.org/forums/body...oration-2.html
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
I stopped removing mine, I am just gonna swap the whole hatch (if I continue) or i'll paint the metal since its rusting... and fill the gaps with some undercoatin
The trunk panel is held on with black sealant similar to the stuff around windshields
Use fishing line to get it loose
The black surround trim is just pinched on there
Move slowly and you can pop it off, but why bother
A replacement hatch is the easiest
Car: 1988 IROC-Z
Pocket, thanks so much. Exactly the answer I was looking for.
userchemical, I did search first. I didnt find anything.
Car: 87 gta
other than that just swap the hatch
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
I recently removed my hatch panel easlily by after removing all the bolts, dont forget the shocks as well, I took some wood wedges and placed them on top one on the edge the other in the center and last one on the oposite edge and used a rubber mallet and tapped all sides til I has able to pull it by hand and walla the declid is off
i just took mine apart a couple of days ago,i took a heat gun and put it on the high setting and moved it back and forth, be careful not to burn the paint off, so keep the heat moving, and slighty wiggle the metal, i will come loose pretty easy. it only took me about ten minutes to do. just remember that it is a pain in the *** to put back on, has to be done in the car so that the body lines still line up. good luck
Street Lethal
04-30-2019 12:14 PM
