door side skirt
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Transmission: automatic
door side skirt
any one know of how to fasten the little trim piece on the door of an 91 rs so that it doesnt bow out? i think it looks like crap. let me know.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: door side skirt
remove door panel . there are a total of 5 nuts holding item on door , 3 are under door panel . sounds like one or more of the studs have broken off . don't worry it can be repaired , remove item , retreive stud , clean , epoxy , set overnite , good to go . i just did mine after removal for paint , check the other studs also . you may want to back them out and epoxy them , i did .
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: door side skirt
If its bowing out. Then the metal hold down strip is damaged. You will need to bend it back into somewhat its original shape.
Or, some of the pop rivets that hold the rubber onto the metal strip are gone. You can just re-pop rivet that.
But to get it off, Tom is correct. 5 nuts, 3 are behind the door panel
Engine: V6 3.1L
Re: door side skirt
so like the inside door panel your talking about?
Re: door side skirt
Yes. Consider some of the following while you're in there:
https://www.thirdgen.org/forums/body...servation.html
JamesC
JamesC
Re: door side skirt
like yea , it's the big panel covered with fabric that has the armrest in the center . ( just kidding ) while your there follow JamesC link as he stated above . i did and more , windows and doors are much better now . you don't open the door up like that everyday . good luck young man .
Engine: V6 3.1L
Re: door side skirt
1992 Trans Am
05-10-2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
