washer fluid squirter nozzle
like the title, i am inquiring about if anyone knows where i can find washer fluid squirter nozzles for this car from....only place i found was this pontiac dealership that said he has to order the whole arm and another one who can get them for 15 dollars each nozzle
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
Re: washer fluid squirter nozzle
i bought a new arm thinking they would be the same so i took off the squirters on my old and put them on the new arm.if your squirters are no good i guess that wont help you
Car: 1990 Camaro RS
Engine: 350 4-Bolt 4bbl Edelbrock
Axle/Gears: 2:73
I don't recommend doing this, but I did see a Firebird a while back that someone drilled holes in their hood, mounted those aftermarket chrome-plated LED squirter thingies on there, and ran new lines to them. Worked quite well for the squirters, but one of the LED's had burnt out and the chrome looked kinda stupid...
If you can find a decent mounting spot (say under the rear lip of the hood itself) and want to rig up something to hold them there, you could always grab a couple of squirt nozzles from a junked car somewhere and mount them in a way that they'd hit the windshield. Then, just run your lines and go!
HoosierinWA
10-07-2015 10:15 AM
