Want to rebuild door hinges. What are my options?
See alot of different things on ebay. Mainly for upper door hinges. I see the more oem style rebuild kits for the upper ones that bolt in and then I also see greaseable fittings
Also, only rebuild kit I seen for the lower are the pin and bushing kind?
Any other options for either hinge?
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
Re: Want to rebuild door hinges. What are my options?
TDS - top down solutions
did both doors with there kits and they work great
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
how hard was it to install and remove the old ones?
any special tools or what did u use?
and did you need a second person to hold the door up?
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
BigBadJohn, the TDS kits are everything you need to need to do one door.
Car: 92rs
Transmission: 350
I used a dremel tool with alot of little cut off blades to get the old ones out.
then as said a floor jack and wood or pad to hold the door up .
Also do only one hinge at a time.new ones go in piece of cake.
good luck Mike
good luck Mike
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i would def. go with TDS kit
Just lost an auction for a tds kit. Went for $46 shipped. Know its worth more than that but def need to focus most of my money on my transmission work right now
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
i replaced my bottom one and it fixed it a little and then made up for it by adjusting the door it self .
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock?? I'm not sure
My doors are starting to sag now. It seems like they can be fixed from bushings and the pin? How would I know it's the bushings/pin vs hinges themselves? Any tell-tale signs of hinges being the actual problem? I saw the kit, but I would hate to pay 200+ shipping for a kits that replaces the pin/bushings if my problem is the hinges themselves.
Car: 92 Camaro RS
Engine: 305 TBI
Come on guys.. nada?? Has anyone ever had to do theirs?? Is it easier to replace everything? Or just the pin??
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
