help with door panels...
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
im replacing my window motors and i found a plastic spreading sheet across the door. it look like its there to protect the inside of the panel.... anyways i found a number on the drivers side of the plastic sheet.. l.h. 10064453... is there a place where i could get replacements for both doors cause it was glued on there and i had to rip it off to get to the door motor, window motor, and the door handle..... i need two plastic sheet coverings...
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: help with door panels...
If the dealership no longer carries them you can order them from http://www.classicindustries.com or, make your own out of heavy plastic sheeting.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
2 days ago i had the same problem . ( putting g.f.x. back on after paint ) i had some heavy plastic more than large enough to cover the doors . with clothes pins and a hot glue gun got it recovered in about 10 mins. . you will need to cut slits for switchs , door handle , etc. . trim excess , hot glue gun worked great . you can also touch plastic sheet with tip of glue gun and put glue under sheet all other center parts of plastic sheet . works great , cheap too . cost less than $10.00 . good luck . ( easy job )
