is there...?
Car: 91 Camaro vert
is there...?
I am thinking of changing my front grill from a Rs to the z28, i want to put the fog lights in and make them work...is their wiring already set up or do i half to run a howl new wire threw to get them working?
-also are their some z28 grills that dont have the mounts for the fog lights?
Car: Blue 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Re: is there...?
i have a 92 RS. i don't think there are wires running to the bumper. and yes, there are some z28 grills with no mounts for the fog lights. i have the z28 grill on my RS. looks sharp.
Car: 1990 Camaro RS
Engine: 350 4-Bolt 4bbl Edelbrock
Axle/Gears: 2:73
Re: is there...?
I put a '91-'92 Z-28 style grille in my '90 RS and it looked GREAT. I had to "rig" the mounting for the fog lights, however, and run my own wires and switch. I basically set it up on a 3-way switch, that ran (from top to bottom) "On, Off, On w/headlights". I was quite happy with the end result.
Car: 92 z28, 07 Silverado
Engine: LS1, 5.3
Axle/Gears: 3.73, 3.23
Re: is there...?
I put the stock fog lights in my car. It really wasent bad at all. The wiring is already there, but only runs untill about halfway with the wire loom with the headlights(to about the front of the motor). In the dash, the plug for the switch is there too. All I did was hook up a power wire to that switch. Everything else was hooked up except for the power. Once I did that, works great
