Weatherstripping question
I just replaced my t-top/door weatherstripping and i'm getting a gap at the rear of both driver and passenger window, where the window meets up with the t-top. Tried doing numerous adjustments and repositioning, and i can't seem to get the glass to sit on the area right. Was wondering if anyone had any suggestions for trying to get it to sit right or what i can do to fill the gap?
Thanks for the info
Thanks for the info
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Re: Weatherstripping question
How big is the gap?.It could be the up/down adjustment for the t-tops at the rear.It may need to be adjusted down a bit.
Alicat.
Alicat.
Car: 86 iroc
Engine: 496ci
Transmission: stock t5
Axle/Gears: stock/323 posi
I just replaced mine too. I had the same problem, i just let it be for about a week and a half and it settled into position. My new seals were way poofier .. lol then my old ones so it did hold it out a little but i doesn't anymore.
Car: 86 iroc
Engine: 496ci
the t-top adjusts by taking the front plastic A pillar cover off and the plastic trim piece that goes down behind the seat by the rear speaker. once those are removed there are 2 little adjustable plastic pieces on either side that the t tops lock into. just loosen the two screws and and slide them up and down to the desired height.
