Did i miss something?
Car: 86 iroc
Engine: 496ci
Transmission: stock t5
Axle/Gears: stock/323 posi
I just installed the seal that goes behind the side mirror and sits in a vertical position. I seals the front of the side windows to the little black plastic triangular piece. I put it in about 2 days ago. Whenever i try to roll the window up, that seal is rubbery so it grabs the window and keeps it from going all the way up. Did i put it in wrong maybe or should i try to use a little bit of silicone spay to make it slide easier?
I hope that makes sense, kind of a hard to explain.
Thanks.
Thanks.
Car: 88 trans am gta
Engine: 305tpi
Axle/Gears: 9 bolt 3:27
Re: Did i miss something?
j had the same problem. if you take off the door panel you can adjust that filler panel. this helped on mine but it took about a week of having the window up to get it to seat properly. i just put a little silicone on it for first few weeks so i didnt burn out the window motor
Car: 1988 Camaro Sport Coupe
Engine: 305 TBI
Transmission: 700-R4
Axle/Gears: 10 Bolt, 2.73 open diff
Try a little spray lube first. If that doesn't work, you might have to adjust the window track just a little
Car: 86 iroc
Engine: 496ci
Allright, thanks guys. Ill give that a try and let you know how it goes.
