Retrofitting factory fog lights on 91-92
Car: 1992 Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 3.23 Posi
Has anyone done this, add the fog lights that were on a T/A to a Formula? It looks like it would be fairly straight forward. Just get the switch, lights, and fashion a wire harness. There's a plastic cover over the area where the lights should go, so I'm not sure how you'd deal with that.
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Retrofitting factory fog lights on 91-92
get some factory foglights with all the brackets
take the plastic covers off and install all the brackets and the foglights
Engine: 5.7 TPI
What do you need for a wiring harness then? Does the existing wire harness have any provisions for the fog lights and switch?
