Front Fascia
1 Post
Car: 91 RS
Axle/Gears: 3.45
Front Fascia
I have an RS, you know, the one that has a black grille. my question is where can i get the one thats open and it says "CAMARO" in the middle, and usually theres a fog light set up. im sure yall get the point. can i just bolt that one up to my RS? and where are they available???
Car: 88 Formula 350
Engine: l98
Axle/Gears: 3.23 9-Bolt
Re: Front Fascia
Yes, it will bolt right on, and they can be found in numerous places: ebay, classic industries, year one, etc.
1 Post
Car: 91 RS
Axle/Gears: 3.45
Re: Front Fascia
Ah sweet. is the correct way to label it as a Z28 front end right? i checked in the year one catalog and it says it but theres no picture so it was kinda hard to tell. just wanted to make sure.
1 Post
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: Front Fascia
Here is where I got mine: http://moderndaymuscle.com/inc/sdetail/852. I believe it is an IROC style grill, but I am not too sure on that.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Front Fascia
the grill's can be had with CAMARO or chevy bowtie in the center . i put the bowtie one in my rs . easy job .
1 Post
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: Front Fascia
Yeah, the "camaro" one is correct for the earlier models (I believe pre 90) and the bowtie one was on the later models. however, they are identical so they fit any model.
Re: Front Fascia
yes it look's , fit's like stock . much better look than the louver's . secures a little different but no big deal . when you get the new one , compare and you will see . upper mounting screws the same , lower ones on the sides of center section . i put 2 extra ones ( 1ea ) on both sides of center section . like i said , easy job .
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Re: Front Fascia
I replaced the one on my 91 RS with the bowtie grill, and added my own foglights... If i could find a picture (i know I have one somewhere) I will post it up
1 Post
Car: 91 RS
Axle/Gears: 3.45
Re: Front Fascia
Oh thats cool, thats the idea i was going for because i dont really like the flat black grill. if you could find a pic, that would be awesome. and did the lights mount to the top inside? thanks.
Car: 1991 Camaro RS
Engine: L98 350 TPI
Re: Front Fascia
I actually made my own brackets out of some spare flat earth-quake brackets my parents had in their backyard, then drilled 2 holes in each and got some bolts from Home Depot... I didn't attach the brackets to the grill part only because I didn't want to cut holes in it.
I couldn't find any pics that I have, but I will take some tonight
Car: 1991 Camaro RS
Engine: L98 350 TPI
Re: Front Fascia
Here you go... Sorry about the bad looking front... I got into an accident a while back and am in the process of repairing the front end. The front gfx was broken during the accident so it fell off... I know, it looks like crap.
I tried to get a picture of the brackets that I made, but I couldn't get a clear shot of it without taking off the fog light and I didn't want to do that today (not enough time)...
Anyways... good luck with your swap, it was really easy. I wouldn't have put the front plate back on, but I got a fix-it ticket for it (damn California...)
1 Post
Car: 91 RS
Axle/Gears: 3.45
Re: Front Fascia
1Aauto
Sponsored Vendors
08-26-2015 02:18 PM
ProtoMaster22
08-26-2015 07:50 AM
