Widest rear tire???
1 Post
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
Widest rear tire???
I am looking into buying a set of Crager SS rims, the rears are 10 inch rims, so what is the widest I could run? they were on a 2nd gen and he said they would rub under hard cornering... do the 3rd gens have more/less clearence? any help appreciated...
Car: 1984 Camaro Z28
Engine: '92 LT1
Transmission: 700R-4
Axle/Gears: 3.73 factory posi. disc brakes
Re: Widest rear tire???
I have 10" rims with a 12" tire(295) the do rub like hella bad so what I did is put air shocks and raised my rear end .that worked really well
Engine: '92 LT1
if you run 275 yopur in the green as far as I know
1 Post
Engine: 383
what does everyone think the ideal tire size would be for the 15" rim? The wider the better... also 275's wont stick out too much will they?
1 Post
Engine: 383
hmmm, is there a difference between the grizzleB and 25thZ28 wheelwells? he says they rub... I have an 83...
Car: 87 GTA
I've run the BFG 295/50R16s on the back of my old 92, with no problems, and I know a guy who currently is right now.
I'm kinda eager for my rear tires to wear out. I "help" that out a bit!
1 Post
Engine: 383
so another 295 on a 1992... anybody with other years run 295's? is the 1992 wheel well any dif from other years?
1 Post
Engine: 383
ok so 295 is in millimeters right? this would be 11.6 inches, so GRIZZLEB, are your tires 12 inch or 295's??????????????
Car: 87 GTA
BFG 295/50R16
CrazyOldBiker (09-06-2024)
Car: 87 GTA
Or go to your local NTB/Discount Tire (my favorite place here) and ask them. They'll know. Tire height will also play a factor, but that is determined by the sidewall % of the rated width.
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
They look baddass, and have that tucked in - beefy tire look with no rubbing issues whatsoever
1 Post
Engine: 383
ok so on tirerack i found BFGoodrich Comp T/A Drag Radial 315/60-15(for 50 a piece) and BFGoodrich g-Force T/A Drag Radial 2 315/60...295/65...and 275/60, and 50. which of these will fit???
Car: 89 RS
Transmission: th350
This is a 295/50/15 on a 9" rim with 4.5" backspacing
This is a 275/60/15 on a 8" rim with 4.5" backspacing
Both have rubed when hiting a bad bump but the 275s didn't rub as much. I also rolled the rear wheelwell lip in and neather would rub when taking a hard turn but if i hit a dip and the whole back of the car squated the 295 still rubed some.
Edit: btw a 295/50 is a 10" tire and the 275/50 is 9"
1 Post
Engine: 383
oh, i'm not sure whether or not these rims are backspaced enough to kind of tuck them in so they wouldnt rub, they are probably about the same as the rims on the 275's.
Car: 89 RS
Transmission: th350
Those are crager ss's on the firebird with 275s. If you roll the finder lip up you wont have a problem. Also the rearend in that car is alittle off center, and the tire that sticks further out did most of the rubbing b4 i rolled the lip. Btw you had to hit a BIG bump or dip for it to rub it wouldn't rub just taking a corner or anything.
Do you know what the back spacing is. Probly 4.5
CrazyOldBiker (07-21-2024)
1 Post
Engine: 383
ya i think it is 4.5, how did you roll the lip? with a hammer? ok so i have had people say 275, 295, and 315's... also, the second number (45, 50....) is the bigger the number, the more the tire will bulge, which makes it more prone to rub????
Car: 89 RS
Transmission: th350
The first number (275) is how wide it is, the second number is (60) is a % of the first number, and it shows how tall it is.
A 275/50 would be perfect for you. It is shorter than the 275/60 i had so you might not have any problems rubing.
1 Post
Engine: 383
the rims have 295/50 on them right now so maybe i will test fit them and see if they rub just sittin there.
Car: '91 TA vert
Engine: turboLSx
Wait...So you put a 19" tire on an 18" wheel?
Not that my tire sizes are close to what you guys are wanting to run. I daily drive on a 295/35-19 on a 10" wide wheel. Would've gone wider but they didn't make the tires I wanted wider. Looks like I still have another 1" of tire I could stuff under there.
1 Post
Engine: 383
the 295's are pretty wide and have some tread left on them so i would be very happy if they fit fine... is it a noticeable difference between 295 and 275??
Car: 89 RS
Transmission: th350
Ya there is a noticible diffrence. I have had 295s for a long time so when i got the firebird with the 275s the back tires just seemed to narrow, even tho there is only a 1" diffrence.
Here are my 17x11s on the rear with 315/35/17s. Minor inner fender massaging, minor work on the bump stops, no fender lip work, no rubbing.
Attachment 447742
Attachment 447742
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
I sincerely hope no one reads this ancient thread and then goes out and buys air shocks to clear ill-fitting wheels/tires. It was a dumb idea way back when this thread was posted, and it hasn't gotten any smarter since.
T.L. (08-23-2024)
Car: '83 Firebird (T/A Clone)
Engine: 350 carbed with L-69 components
Transmission: 700R-4 w/2000 RPM stall converter
Axle/Gears: 10-bolt/3.73 ..
Yep, and air-shocks are best suited for full-frame cars, not uni-body cars, and NOT for the purpose of clearing tires that are too wide...
ironwill (08-23-2024)
Attachment 447742
Attachment 447743
Attachment 447744
Attachment 447745
Attachment 447746
Attachment 447742
Attachment 447743
Attachment 447744
Attachment 447745
Attachment 447746
nolanr0413
09-06-2024 12:26 PM
