Aluminum bumper supports
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Aluminum bumper supports
if your speaking of the bumper reinforcement, buy them, i haven't a clue. I don't think that they procude them. Get them, in a junk yard, i believe the 4 cyl. cars had them from what i've read, someone can add to this if i'm wrong, but junk yard is your best bet.
Car: 92 Camaro RS
Transmission: T5 manual
I believe that Classic Industries has aluminum bumper supports for firebirds in their catalog.
oem a hard find and too expensive. aftermarket looks identical and much cheaper. many autobody shops can get them for you, make a friend at a body shop.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I got mine off a 82 z28 in a junkyard. Required a little modification on the honeycomb, but not to bad.
Car: 87 GTA
I got one off a 84 Z28. I've thought about modifying it to fit my GTA, but just haven't tried. The Camaro ones are like 2" too wide for Firebirds, from what I hear. Just hafta trim the ends a bit.
gixxer92
05-18-2017 11:20 AM
bigjay89gta
10-15-2015 08:04 AM
