Ttop seal metal track rusted out
Car: 1972 GMC
Engine: 355
Axle/Gears: 4:10
Well I now understand why my ttops leak, does anyone know if the rail that the ttop seal fits into is available? The roof itself seems to be fine but the rail that is prettry bad in a couple of places. It is spot weled in and will be a chore to remove but dont know what else to do??????? HELP!!!!
John
John
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Re: Ttop seal metal track rusted out
Try Ebay?
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Yea, EBAY has a few of them floating around. Also try the classified section on here. I saw one a couple weeks ago I think in good shape. However, it is going to run around $100 for one. Just prepare yourself and take deep breaths.
Car: 1972 GMC
Engine: 355
Axle/Gears: 4:10
Thanks for the reply, I think the cost of the rails will be alot less than rotted out floor pans and not being able to drive in the rain or wash it or replacing the carpet etc. It dosent just leak in runs in. We drove it to the MI nascar race last year which was rained out and the interior was soaked by the time we got home. So it isnt going out again untill I get it fixed it is in excellant condition except for the rails and is worth the efort it will take to repair.
John C
John C
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
You're talking about the channels welded to the body of the car, not the removable center bar between the openings, right?
Mine are the same way in places. I pulled the weatherstripping, took a grinder to the rust, and primed it. For a temporary fix I put the old weatherstripping back on and siliconed every spot were the channel was rusted out. That was back in September.
In about a month or so I'm going to fix it right since I've got new weatherstripping waiting to go on the car. I made some new metal channels to weld in place of the rusted/rotted ones on the car. Since I work in a sheetmetal shop I made mine for free. You could probably get them made for you pretty cheap at a local sheetmetal shop. The old ones will need to be ground/cut out and the new ones welded in place.
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
Got any other pics of the car? i have been looking for pics of black 91-92 Z28's.
Cheers,
Richard.
Cheers,
Richard.
morrow
01-13-2024 12:29 PM
