thinking of making a sport coupe
Old 02-05-2008 | 07:52 PM
91blackrs's Avatar
Car: 91 camaro
Transmission: 5 sp
Axle/Gears: stock 10 bolt
I know this might sound a little wierd but i have a 91 camaro with ground effects and i really like the looks of the sport coupes. i was wondering if its possible to change and how hard is it. do i just need new front and rear bumper covers or do i need new fenders also.
Old 02-05-2008 | 07:57 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: thinking of making a sport coupe
if your eliminating the ground effects all together then you would need to fill holes on the doors, fenders, rear quarters, replace the bumpers as the rear is molded in and the front is bolted together, and then eliminate the braces for the ground effects for the side skirts.
Old 02-05-2008 | 07:58 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i got a friend with an s/c and i will say its a diffrent look, i think all you need to chage is the front clip and back clip and then clean up where the ground effects are on the sides, but im not to sure of that also
Old 02-05-2008 | 09:05 PM
RacerX13's Avatar
Car: 88 Formula
Engine: LB9
Axle/Gears: 3.45
I want to do the same with mine. I have done some searches and research on here and I get the impression that to swap the front bumper cover you need to swap all the reinforcements and brackets also. Not sure on this, but I think everything forward of the core support is different on the non-GFX style nose. Maybe MW66Nova can chime in on this since he has done the swap on his. I love the clean look of the sport coupes.
Old 02-05-2008 | 09:36 PM
84redta's Avatar
i don't believe so...only diff in under the front is the cusioning should be diff for 82-84 and 85-92. GFX shouldn't make a diff to my knowledge as it gets attatched to the bottom of the bumper cover which is connected to the bumper reinforcement reguardless IIRC.
Old 02-05-2008 | 09:40 PM
91blackrs's Avatar
Car: 91 camaro
Transmission: 5 sp
ya i figure i was going to have to fill some holes. i was just worried about having to change alot of stuff like the core support. ive searched and really havent found any good info on it. maybe nova66 will make his way in here and help us out.
Old 02-05-2008 | 09:46 PM
84redta's Avatar
if not i got a complete 86 bumper and a complete 88 w/GFX bumper set up (reinforcement, cushion, cover) and i will compre them friday when i get back to my shop from college.
Old 02-05-2008 | 09:52 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
84redta pretty much summed it up.
Your biggest issue aside from filling holes, will be removing the bracket that is spot welded to the rocker panels. It runs pretty much the length of the door along the rocker.
The only thing I don't like on the sport coupes is the three holes above the grill.
My old 87 SC had an 82-84 Z28 nose minus the lower gfx on it. Actually didn' look too bad. That's how I can still spot the car lol.
Old 02-05-2008 | 09:58 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
You might find a rusty surprise behind the GFX too...
Old 02-05-2008 | 10:58 PM
91blackrs's Avatar
Car: 91 camaro
Transmission: 5 sp
ya im planning on there being some rust to fix, ive checked in some of my magazines and they list different fenders for the 91 and 92 camaros than the 82-90. did any of the body lines change or did they stay the same from 82-92.
Old 02-05-2008 | 11:20 PM
84redta's Avatar
not to my knowledge...if there was any change it was 84 to 85, of which and can almost promise you there was none. And from word of mouth i've heard of people using 88-90 fenders on 91-92. To my knowledge it's all the same...i think it may just break it down 82-84 plain and body kitted, 85-86 plain while 85-90 body kitted, and then 91-92 body kitted. I think thats a fair break down of how the fenders may show up which would just represent the hole differences for the body kits.
Old 02-05-2008 | 11:23 PM
RacerX13's Avatar
Car: 88 Formula
Engine: LB9
Axle/Gears: 3.45
I have seen it said on here that the 91-92 fenders have a slot stamped out in them that a tab on the GFX fits into but I haven't pulled mine apart to verify it.
Old 02-05-2008 | 11:32 PM
84redta's Avatar
yea like i said...i can only assume the ground effects bolt on slightly differently (because of the air scoop), thats all i would assume, i could be wrong. Haven't owned or closely analyzed one so i can't speak 100% promises. You could ultimately see if you could go to a JY by you and see if they got any 85-90s with body kits and just uninstall the inner wheel well protector to see how much difference their could be. Otherwise someone else can chime in with a little 91/92 experience.
Old 02-06-2008 | 04:31 PM
91blackrs's Avatar
Car: 91 camaro
Transmission: 5 sp
thanks forall the help every one i really think im going to go for it, im just waiting to hear back from 66nova. my only other question is i would like to replace the fenders any way does any one know of a company that sells the fenders and bumper covers brand new for no ground effects cars thanks.
92camaroJoe
07-29-2023 07:57 PM
theshackle
09-17-2020 08:26 AM
midge54
01-29-2017 07:00 PM
sreZ28
08-14-2015 07:48 PM
92camaroJoe
08-13-2015 06:07 AM
Quick Reply: thinking of making a sport coupe
