Fiberglass powerbulge hood ?
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
I've been searching for anyone that makes a fiberglass hood with the powerbulge (pin on or othewise). I got a metal one in a trade and now I really like the look of it with my notchback. Does anyone know who makes one, and maybe any feedback on the quality?
1 Post
Car: 84 Z28
Engine: carb 305
Re: Fiberglass powerbulge hood ?
I was going to buy a 82 trans am a couple years ago it definatly didnt have an aluminum power bulge. those things are really heavy But beautiful hoods they flow with the car better then any other hood out there. DO you know witch cars actually came with the aluminum PB?
1 Post
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I am considering this aluminum power bulge hood thing a myth until I see a picture of one! I've heard it before but never saw any evidence that they exist.
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
I've never seen an aluminum one in person, but someone(okfoz, I think) has posted a pic of the underside of one showing the "A." But it would be almost impossible to find anyway. So that leaves you only with the steel hoods.
And if weight is your issue, then try to find one from a Formula. Those later bulge hoods are lighter than the ones used on '82-'84 TAs.
IMO, the power bulge hood is the best-looking hood ever offered. It "defined" the original thirdgen TA. No other cosmetic part is as unique, making it the single, most important Firebird body panel of the generation.
And since it isn't being reproduced, and it's not likely that it ever will be(at least, not in the near future), it's time to begin stockpiling the good ones when they're found.
Car: 87 trans am
Nobody reproduces the power bulge hood at all, not in any material, and brand new ones from GM don't exist anymore. So if that's the hood you want, then you'll have to settle for another used one, either from a private seller or from a junkyard.
I agree with all of that, and I already have a formula hood. I just thought I'd see if anyone knew something I didn't . I doubt the alluminum one will fall in my lap, so I guess I'll either make due with the weight or cut this one up. Too bad I don't know a fiberglass maker. Seems like you might at least break even making a fiberglass version...maybe.
1 Post
Car: 1984 Trans Am
a gray painted bulge hood with "not steel" written on it DOES NOT equal proof it's aluminum! I'd have to see the underside and actual exposed aluminum. I'm not saying you have to provide this evidence, I'm just saying it's hard to believe they exist without the evidence. Anyway, why would GM even produce an identical hood in aluminum? Also, I have an 84 TA and I swapped the original hood for a later formula hood due to rust and a dent. They were perfectly identical from everything I can tell. I don't see how the formula one would weigh any less than the earlier T/A version.
I can't confirm that there's a difference in weight because I haven't actually weighed them. But I pulled two from '84s last year, and they each SEEMED to weigh a lot more than the hood on my Formula. They each seem a lot more "solid" than my Formula's hood, too. And other people have posted similar reports.
http://www.vfnfiberglass.com/site.htm
They make pin on and bolt on bulge hoods, no pic but they have them
Its VFN so youll have to spend a good bit of time fitting it to the car
A magnet would
GM had many factory racecars. This was their way to "cheat" a little
Do a search about alum hoods on the history board
Not all early T/As got them
Also, if youre dead set on which factory cars got em, ALL firehawks did
Difference should be minimal
Bracing was slightly changed and the vent was made into a fixed piece for later hoods
Thats all
I have an 84 TA and ...
Thats all
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
That's great to know; I don't mind re-doing a little VFN fiberglass if the majority of the work has been done!
Awesome!
Awesome!
Car: 87 trans am
I forgot about VFN, that's a good deal on the pin on, might have to check it out.
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
