How to remove the lock cylinder on the hatch
I have a new lock cylinder to go into the hatch area but wanted to see if anyone knew how to seperate the lock cylinder from the motorized hatch release ? I had it all apart but something wouldnt let the cylinder disengage from the motor assembly so I threw it back together to try another time when it warms up a bit around here
Anyone have any advise they would like to share on that ?
Thanks for any input
Kaycee
Kaycee
Car: 82 Z28
Engine: 305, some mods
Transmission: 280 metric
Axle/Gears: 3.23 Limited Slip
Re: How to remove the lock cylinder on the hatch
there is usually a clip that holds that thing in there, you should be able to get to it with a pick or some similar tool.
and if that doesnt work might i suggest high grade explosives, because by that point you will be so pissed off that that will be what you feel like using.
1992 Trans Am
05-10-2023 07:19 PM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
