Grill removal
Old 10-23-2007 | 06:11 PM
sadeks8's Avatar
Car: 91 Camaro RS
Engine: 3.1L MFI
Transmission: Hydra-Matic 4L60
Grill removal
i have a 91 rs with the louver style...anyone know what screws i have to remove...i saw torx screws on the front but im not sure if those are wat holds it in...
Old 10-23-2007 | 09:16 PM
zdc590's Avatar
Re: Grill removal
I did this to my old rs way too long ago to remember exactly, but if i can recall anything, you have to get under the car, and on the back of the grille theres 4 or so screws holding it in. Theyre pretty easy too see, i dont recall where but im gonna say top left/right and bottom left/right is a good guess. I think there might be 2 more at the center of the grille on the front. Im sure someone can correct me. But in all honesty, if you get down and look for them, its a very easy job. Just be ready for your car to look very ugly without a grille. As far as what kinds of screws hold it in, all the ones i dealt with were phillips.
Old 10-23-2007 | 09:32 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Re: Grill removal
yeah i believe it is 4 screws, i cant recall exactly where they are either but if you look for them you will find them, it should only take like 5 minutes to remove the grill.
Old 10-23-2007 | 10:29 PM
PhoenixAshes's Avatar
Re: Grill removal
Just did the same with my '91 and I had 6 torx head screws. 2 into the center, 2 more at each upper corner and 2 more at the bottom corners.
PS. Anyone know where I can find another of the louvered grills? Mine died in a dogfight....
Old 10-23-2007 | 11:12 PM
sadeks8's Avatar
Car: 91 Camaro RS
Engine: 3.1L MFI
Re: Grill removal
btw i wasnt planning on leaving it out, i need to take it out to mount an air horn on the brace behind it. but since im taking it out anyway does anyone know if the z28 grill is a direct replacement, or if i have to do some fabricating.
what size torx bit do i need?
Old 10-25-2007 | 11:06 PM
zdc590's Avatar
Re: Grill removal
I figured you werent leaving it out, but damn i just couldnt get over how ugly the car was without one lol. As for direct replacement im pretty sure they are, im unsure of what size bit youre gonna need though.
Old 10-25-2007 | 11:41 PM
sadeks8's Avatar
Car: 91 Camaro RS
Engine: 3.1L MFI
Re: Grill removal
well i have air horns mounted behind it and the z28 grill looks like it sets inward more... i guess ill have to get a set of torx wrenches and find out the hard way...lol
Bubbajones_ya
07-06-2024 09:32 PM
GeneralIesrussi
Carburetors
06-20-2024 08:21 PM
HP52TA
02-03-2018 11:51 PM
Stroopwafel
09-11-2015 07:38 AM
