pictures of camaros with hood pins
Old 10-02-2007 | 10:56 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
for some reason it wont come up with any search results on hood pins
so anyone with pics of them on camaros throw em up
Old 10-02-2007 | 11:08 AM
kerplunk318's Avatar
Re: pictures of camaros with hood pins
https://www.thirdgen.org/forums/cama...-complete.html
Old 10-02-2007 | 11:40 AM
86-Iroc-Z's Avatar
Car: 86 IROC-Z
Engine: 305 V8 carb'd
Best one I got, so here ya go.
Old 10-02-2007 | 01:15 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
cool, just getting an idea of how far to the outside looks good for placement of pins
Old 10-02-2007 | 01:49 PM
im pretty sure 86 iroc z and I used the same method of mounting them. Underneath the hood to the inside of where the screw in rubber stops are there is some flat sheet metal... thats where i mounted mine and drilled the appropriate holes in the hood. By the way does anyone know where to find stainless hood pins?
Old 10-02-2007 | 02:35 PM
86-Iroc-Z's Avatar
Car: 86 IROC-Z
Here's where mine is.
Attached Thumbnails pictures of camaros with hood pins-pins-1.jpg   pictures of camaros with hood pins-pins-2.jpg
Old 10-02-2007 | 03:31 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
awesome thanks guys
Old 10-02-2007 | 06:05 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
my camaro came with hoodpins. i think they look stupid. at least the placment does. the guy that had the camaro before me put them on and they are way to close to center. maybe you will disagree. http://www.cardomain.com/ride/2918464 PS dont mind the hood that looks like it got run over at one time in its life. it is getting replaced this winter.
Old 10-02-2007 | 07:15 PM
86-Iroc-Z's Avatar
Car: 86 IROC-Z
Oh yea, those are waaay too close together. I've never seen anyone put them like that. Looks very strange.
Old 10-02-2007 | 08:34 PM
Stephen's Avatar
Car: 87 GTA
I've seen them that close, but only when it was a full 10 pin, pin-on hood, no hinges.
Here's my wife's Camaro, from when we had it for sale, hence the vinyl letter & #s in the upper corners of the windshield...
Old 10-03-2007 | 12:33 AM
iggy89's Avatar
Car: 86 Camaro
Engine: 79 350 carbed
Transmission: TH-350
Axle/Gears: 3.73 posi
thanks for asking this before I had to . The SS hood I have is warped slightly in one corner so I was going to go with the locking type hood pins to help fix this. They don't look that bad IMO so I think I will be going this route.
Old 10-03-2007 | 04:35 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
had the day off work and was bored out of my mind, so took a shot at doing pins myself. Had originally said i was going to let the body shop do them when it goes for paitn, but thought a **** it, gotta learn sometime
i felt freakin sick when i was drilling out the hood, but it turned out perfect.
Still probably have to drill out the holes a little more the pins just barely fit through. Scuff plates arent screwed in yet but threw em on just to snap some pics. Gotta adjust the pins too, and i dont know if the cables are staying or not, havent made up my mind.
Old 10-03-2007 | 06:53 PM
86-Iroc-Z's Avatar
Car: 86 IROC-Z
That turned out great, bet your glad you did it yourself now.
Old 10-03-2007 | 11:43 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
hell yea do i feel good about the fact that i did that myself
still feel sick thinking about drilling through my hood tho lol
thx btw
Old 10-04-2007 | 05:42 PM
irockid86's Avatar
Car: 88 iroc camaro
Axle/Gears: stock
keep the cables
Old 10-04-2007 | 10:00 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
ya id just like to find some nice ones that have a plastic sheeth on the cable, either that or break the attachment at the loop slide one on and find another way to attach it and make the loop again
Old 10-05-2007 | 07:52 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
i agree with your pin placement, kerplunk, but can you quickly go over the hood drilling procedure? once you locate the pins on the radiator support, then what? there must be some trick to locating where to drill the hood!! without f..'n it up!
Old 10-05-2007 | 08:01 AM
Stephen's Avatar
Car: 87 GTA
When I did my wife's car, I used a da of paint on the hood pin tips, lowered the door until it touched, which left a dot of where to drill.
Used a small drill bit, like 1/8", from below, after masking both sides off.
Then slowly stepped up the drill bit size, until I got to the final size, drilling from the top this time.
Old 10-05-2007 | 08:20 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
lol the dab of paint is the smart way to go
i didnt have any paint so i just *Gently* smacked the corner of the hood down on the top of the hood pin and it left a little scratch on the underside of where to drill.
in retrospect this is not the best way it put a small dent in the hood skin (thats completly drilled out now) and just barely cracked the paint.
could have definitly cracked the paint bad by smacking it down, left a nice little center punch type mark to drill off fo tho.
i used a small drill bit first, then stepped right up to very close to the drill bit size of the final hole.
i drilled it all out from underneath, and covered the top side of the hood of where youre drilling with a whole bunch of masking tape. Not sure if thats the proper way to do it, but ive heard before to cover the area in tape to help prevent the paint from cracking.
Old 10-05-2007 | 09:48 AM
agreed
Old 10-05-2007 | 10:19 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
why would you drill from the top to finish it out? does it make any difference? or i guess maybe just to clean up the hole a bit?
did you put tape over the hole and then drill on the tape or just drill right on the hood
Old 10-05-2007 | 10:26 AM
Stephen's Avatar
Car: 87 GTA
When drilling something, it can cause the opposite side to crack/splinter, etc. If you drill from the top, any cracking/splintering, that might happen, would happen on the bottom side, under the hood, not the outer surface.
Of course, you should use a good masking tape on both sides anyways. I just like to over work it, than mess it up, and spend way more & fixing cracked fiberglass.
Old 10-05-2007 | 10:28 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
makes sense, thanks
Old 10-05-2007 | 10:30 AM
Stephen's Avatar
Car: 87 GTA
Spend the $ though, and start with NEW bits, not worn out, used up bits.
Again, a little $ now, or $$$$$$ later.
Old 10-05-2007 | 10:33 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
for sure, i had a super sharp set of bits around the house so i was fine
ya as you can see above my pins are already in, i still need to drill them out just a hair more so the holes arent so tight, so definitly good info
Old 10-13-2007 | 08:39 PM
SidepipeTA's Avatar
I have put some on my car too. The other pics looks good too.
Old 10-14-2007 | 08:27 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
It looks way bad. But just an idea... you could put two more on the outside. If you spaced 'em right you might be able to pull off that NASCAR look. It wont really fit the car or look better than two in the normal spots, but you've already got two in the wrong spot as it is, so you might be able to massage it a little and make it look okay.
But if it's getting replaced...
Frozer!!!
01-19-2024 04:55 PM
Vintageracer
01-10-2020 05:33 PM
sailtexas186548
Exterior Parts for Sale
02-29-2016 08:40 AM
LittleFranks
08-20-2015 03:55 PM
bryan623
08-10-2015 11:33 AM
Quick Reply: pictures of camaros with hood pins
