Anyone use a T-top weatherstrip alternative?
1 Post
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
Those sets are expensive...at least the good quality ones. I believe mine have gotten flat over the years. I can't remember the last time I took off my t-tops. I know they leak like crazy during a hard rain. I wondering if anyone tried use just regular weatherstripping and caulked it down real good. If someone has done this, let me know or if you've used something else as an alternative.
Ken
Ken
1 Post
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Anyone use a T-top weatherstrip alternative?
Oh Ken,I know a few people that have tried this method and failed.Yes the weatherstrips can be pricey,but well worth it if you want to be able to drive down the road when its raining and stay dry.
Car: 2001 tarus/ and 84 TA
Engine: 408 sb
Transmission: 2 speed powereglide
Axle/Gears: stock:(
SPRAY W-D 40 OR SOMTHING STRONGER TO SWELL THE SEALS. NOT SHURE IF IT WILL WORK ON ALL T TOPS, BUT IT FIXED MINE. IT SHOULD IF THERE THE SAME RUBBER. BUT ITS WORTH A TRY IF THEY ALREADY LEAK???? AND ITS FREE.
I KNOW I AM GOING TO GET A COMMENT SAYING (DUMB IDEA?) WELL IV BEEN DUMB AND DRY FOR A WHILE IN MINE HAHAHAHA!
GOOD LUCK,
ALSO IF THERE REALLY BAD IV SPRAYED BRAKE CLEANER ON THEM AND REALLY SWELLED THEM UP. THEN ARMORALLD THEM SO THEY WOULD NOT FLAKE APART.........
GOOD LUCK,
Car: 89 trans am
Engine: 305 tpi
i heard armorall is bad to use unless you reapply it very often, i heard it makes plastics/rubbers brittle after awhile.. i had the same problem and put a thin bead of clear silicone around the weatherstripping where it meets the body, havent leaked since.. of course this is just my temporary fix until the new weatherstripping and paintjob
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
GM makes a seal conditioner that is intended for that purpose. dont use crap commonly available at the hardware store. if you have local restoration shop, they should stock it. i went to camaro specialties near where i live and the stuff was like 20 bucks for the can, but i dont have any noticeable leaks anymore.
1Aauto
Sponsored Vendors
10-19-2016 08:50 AM
Thirdgen89GTA
11-26-2015 11:04 PM
1Aauto
Sponsored Vendors
10-13-2015 03:06 PM
alternatiive, car, conditioner, reapply, seal, strip, swelling, top, ttop, weather, weatherstripping
