Rear glass metal trim.
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
The metal strip that goes around the rear hatch on our cars tend to rust pretty quick. Does that metal trim that surrounds the rear glass come off any? It looks like its 2 seperate pieces and might can be removed for painting. Or, is this part of the rear glass altogether and cannot be removed?
Ken
Ken
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
Re: Rear glass metal trim.
Its glued on and is part of the rear metal lid. If you want to remove it, remove the hatch, take the rear lid off the glass, and then carefully pry the metal trim off the hatch.
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Best bet is to just mask off the glass, sand of the rust and re-paint it. I'm gonna be doing that this weekend.
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Just mask, sand, and repaint. I sanded/repainted mine about 3 weeks ago. Very easy and cheap. Made a huge difference in the way the rear of the car looked. I also did the same thing to the metal pieces on the T-tops above the windows because the paint was faded off.
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
I did mine in June. Was a pain in the *** to mask because i only had notecards to shove under the metal. So i had to cut to get it to fit the round parts...
1992 Trans Am
Exterior Parts for Sale
04-04-2016 01:50 PM
AkDrifted
08-17-2015 08:45 PM
