Will and aerowing fit a 91-92 hatch?
Car: 1989 GTA
Axle/Gears: 3.23s
I have an 89 GTA but for some reason the first owner had the hatch replaced with a 91-92 style hatch and spoiler. Will an aerowing install on that style hatch or will I have to do some custom work? I have an opportunity to get a used aerowing for like $60, paints cracking but body is intact.
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Re: Will and aerowing fit a 91-92 hatch?
It attaches to the hatch via metal hooks tach welded to the black surround trim
If you can figure out a way for those then go for it
Easiest way is to just swap the whole hatch assembly
Car: 1989 GTA
Axle/Gears: 3.23s
The aerowing one attaches via metal hooks? I don't have the money to swap out a new hatch. Is there any mounting hardware for the aerowing? When I remove the spoiler on there will there be gaps where it mounts?
Car: 87 GTA
The hatch feet and 3rd brake light, use bolts. 4 through the hatch to the wing, 2 through to the 3rd brake light, then 2 more from the 3rd brake light, to the wing. The 2 forward tips, use the metal clips. The 91/92 style, should use the same clips on the wing tips.
Car: 1989 GTA
Axle/Gears: 3.23s
Damn that means I won't be able to mount the center piece without drilling custom holes. That and i'll have two third brake lights. Anyone know if this is possible?
Car: To many to list
Get the correct 85-90 hatch.The clips for the 85-90 and 91-2 ARE different and will not interchange.A 85-90 hatch should be cheap and easy to find.
1 Post
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Hey Tenom,why are you wanting to change that spoiler anyways?IMO the on the car looks very good.I know its not an original factory correct piece,but the 91-92 style is far superior to the 85-90 style IMO. The older ones are very heavy,the sun is not friendly with them because they are mostly rubber so they crack and swell.The 91-92 ones are very light and made of fiberglass(I believe) they don't crack and swell,and I have read some posts on here about the aerowing being heavy for more downforce.IMO that really is a bunch of BS
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
1 Post
OK Zepher,you may be right on that,I don't know. But I think some of us here are more concerned about our cars looking good,and not setting a land speed record of 308mph or more.sorry if I am mistaken on that,but I just don't think the 85-90 gta's and t/a's were originally intended to go 307mph+ .Don't really care if any do either.I just think that Temons car looks good the way it is,and that the rubber aerowings are junk.
Car: 1989 GTA
Axle/Gears: 3.23s
I just don't like the 91-92 spoiler. It's just to small and doesn't complete the rear.
Street Lethal
04-30-2019 12:14 PM
