lubing power antenna
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
ok so whats the general opinion on this.. dry grahite?? the stuff that comes in a spray bomb that is propelled by alcohol seems to be the best idea I think.
the problem; my power antenna doesn't go all the way down... it stops about two inches short.
any other ideas?
any other ideas?
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: lubing power antenna
i would try some white lithium grease on it. I've pretty good luck with this stuff before.
I was under the impression that a liquid/grease lubricant is something I should avoid since dust and dirt would stick to it compounding the problem.
The graphite spray uses alcohol which evaporates quickly.
I don't know what to do with it at this point, I've already replaced the antenna twice and I don't want to do it again.
thanks James, I'll give it a try.
sailtexas186548
08-24-2015 10:11 PM
