Budget clear coat fix
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: '92 firebird
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 10 bolt 3.42 gears with eaton posi
Well, the clearcoat started peeling on the the front bumper of my bird a few months ago and i hate the way it looks. i dont have enough money right now for a new paint job. (the whole car could use one)
I was thinking about sanding down the clear coat and aplying a few coats of good rattlecan clear and wetsand/buff for a temporary fix. anyone tried this? thoughts? tips?
can i just feather out the areas that are peeling and sand the rest of the clear coat enough for the new stuff to stick or do i need to sand the whole bumper down to the base coat?
Car: 88 gta
Engine: 350 tpi
Re: Budget clear coat fix
I tried it and in the end it looked just aful. you will need to re paint the entire bumper if you do. also the paint is insaneley thin. I was sanding with 800 grit and still had burnthrough to primer.
1 Post
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
i used 1500grit wet sand paper then buffed it on my friends maro..might stay a lil faded but comes out way better
Hotrodboba400
12-10-2019 07:07 PM
