Metal t top pieces??? Help
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
as you all probably know Im replacing the t top seals in my TA, im still working on prep work and today i removed the 2 metal pieces(drivers side) that attach to the body which are both rusting badly. the one closest to the door handle came off easy but the one on the window side is all bent outa shape. i figured this wouldnt be a problem because the t top kit came with that piece... or what i thought was that piece. turns out the new one i have is about 4 inches shorter and none of the holes match up. I guess thats Classic Industries for ya. Anyways does anyone know a place that sells the OEM metal pieces
or a reproduction that actually fits? I would be interested in a used set as well in good condition if anyone parting has them
1992 Trans Am
05-10-2023 07:19 PM
1Aauto
Sponsored Vendors
08-24-2015 03:40 PM
