New Guy posting up project pics
HI everybody i am new here and was surfing the web for some info to complete my resto and firgured it share my work ...its a 83 TA but the pics are poor due to lighting in my garage ..it was basically stripped down to the bare shell ..the body was totally solid with no Rot or Major damage ..the fenders however were junk ..these pics were taken after the initial body work was done and the first coats of PPG primer were applied ..the Primer was the Block sanded out with 320 grit and any low spots or imprefections left were smoothed over with Polyester filler and blocked out ...this is how it sits now ..next will be a few more coats of PPG primer Then back to block sanding with 400 Grit Wet then onto 600 Grit ..
onto under hood ...the battery tray was rotted out to i drilled out the spot welds and headed to the pick and pull to drill out a solid one ..after that was all welded in engine compartment was stripped bare and primed with PPG primer ..the primer was sanded with 320 and a red scotch brite pad ..after that a coat of sealer was laid down and 3 coats of gun metal grey metallic and 2 coats of low gloss clear ...sitting in there is a 5.7 liter bottom end from a 91 corvette and some polished /ported /gasket matched heads with erson roller rockers ..the rest of the body should be jammed in and painted this weekend if all goes well ...
thanks ..well its going to be PPG gun metal grey metallic base clear ..i also have some custom painted on badges and birds for this probably going to ghost them on with a translucent pearl ..there is a set of new GTA wheels black and chrome and some other neat things i`ll be posting ... ..
Zachattack0925
08-12-2015 09:54 PM
