outer door window weather strip help!
i want to replace my window strips on the outside of the window. i looked on hawks and they have "outer window felt" and f body has "exterior window sealing strip" are they the same thing or are there actually 2 pieces for the out side of the window? i thought it was one just want to make sure. thanks
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
The part you are talking about is one piece. I replaced the two on my Formula this past summer. Worth it, but a bit of a hassle to access some of the screws once you have the door panel off. Good luck.
Hotrodboba400
12-10-2019 07:07 PM
