Back hatch is not aligned
Old 12-29-2006, 04:41 PM
84CamaroSS's Avatar
Car: 1984 Camaro
Engine: 350 bored .30 over
Transmission: TCI 700-R4
Axle/Gears: Stock 3.23 i think
When i close my hatch the poiler comes out about half a inch past the two side body spoilers. How can i fix that. Any help is greatful
Plus it takes me about three hard closes to clse it.
Old 12-29-2006, 04:53 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
loosen the bolts at the top of the hatch, push the hatch in some more, and re tighten the bolts.
Old 12-29-2006, 04:58 PM
84CamaroSS's Avatar
Car: 1984 Camaro
Hey thanks i will try that
Old 12-31-2006, 06:32 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
You might want to have your hatch open of coarse to move it around easier.
Old 12-31-2006, 07:22 PM
TGO - 10 Year Member
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You also forgot to mention propping up the opened hatch and removing the hatch struts from one end. Otherwise the force of the hatch strut will push the hatch further to the rear. You may not be able to fully adjust it at the hinge. The other place to adjust it is the metal portion at the rear of the hatch where it attaches to the glass.
Good luck, Lon
Old 12-31-2006, 07:24 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Thanks Lon, forgot about that. Been a while since I re aligned mine, I just had to remove the struts, and push it in.
madsv1000
08-20-2015 06:45 AM
383backinblack
08-15-2015 06:36 PM
bbsr72
Brakes
08-12-2015 10:44 AM
3rdgenparts
Exterior Parts for Sale
08-08-2015 11:48 AM
johanlindgren
Wheels and Tires
08-06-2015 03:32 PM
Quick Reply: Back hatch is not aligned
