83-84 GFX's fit on a 1986 Trans AM?
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Would 83-84 GFX's fit on a 1986 Trans AM?
like same mounting holes on the doors are my most concern
Any ideas lets me know I'm changing up my 1986 body.
82 83 84 didnt have ones on the doors
at least not the regular t/a's like my 82
they only had a piece just in front of the wheels and nothing anywhere else
want pics ?
good luck
want pics ?
good luck
Axle/Gears: no idea
i know for a fact 1984 trans ams had a complete ground effect package. I believe 1983 had the same but not 100% certain. And your right in 1982 they only had those 2 front fender flares and 2 rear things in front of the rear wheel wells.
And actually I am doign the same swap 83-84 on my 1986 trans am. I have to buy the front and rear bumpers from 82-84 and bought the door ground effects from 84 and because the 85-90 door effects are taller than the 83-84 door effects the 86 holes are taller and have to be welded shut and smaller holes a little lower have to be drilled for the 84 to fit on 86.
I'm doing it I can send you pics once i'm done. But wont be till end of june.
but the lower rocker door panels should bolt right in but thats the only thing i think will fit without some "minor" fabrication
Car: 87 TA
84 TAs have the complete wrap around GFXs from the 83 pace cars. other than that I believe that Randy is right. But no, I don't believe that early model GFXs will fit. at least not without a bit of modification.
Axle/Gears: no idea
wow i didnt even realize that i answered my own post haha sry guys i got the answer on how to make them fit. hopefully someone else can have use of this thread on their car
ambainb
04-25-2016 09:21 PM
