what is the deal with T-tops!!!
Car: 84 bird
I have a leak at the front corners of the t-tops, big surprise I know, however, following the FAQ on this site I had just completely removed all the weatherstripping, etc, etc, repaired all the rust in the channels, etc etc, and I thought I had it licked. I have made a lot of progress my back seat no longer gets wet however my driver's seat still gets dripped on and now my passenger leaks also. I thought I had it licked like I said sooooo..... I'm either overlooking something obvious or I just don't have a clue anyways I would appreciate any help with this, Jeff
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
T-tops are known for problems like this once they start leaking it seems like they never stop no matter what you do. You could try making them hold down tighter by adjusting the pins
Car: 84 bird
yea thats kinda where I'm at - no matter what I do.....
I got them cinched down pretty tight already, the weatherstripping is new shoot I thought that it would be all good after I fixed all the rust holes
thanks dude i guess it helps just to know i ain't cuckoo
Car: 1987 Z28
Transmission: auto
Axle/Gears: ?
I solved my T top leak problem by installing self adheasive weatherstripping purchased from Home Depot around the perimeter on the glass tops. The size was 3/4" wide by 3/8 thick approx. So far it has worked. I cleaned out a little rust and the existing rubber molding first.
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Dude, I am right there with you. I spent a long time this summer doing my t-top seals the right way, thought I had the problem solved, but nope, still leaks.
You are not alone, brother.
Car: 1985 Chevy Camaro Z28
Engine: LG4 305 v8 w/quad barrel carb
Axle/Gears: 3.08
Should have been fixed... but no
me too... I even replaced the center as mine was rusted more than bondo could repair... but still leaks similar to yours... I wanted to be able to put a headliner back in, but at this rate I don't know if thats gonna happen... has anyone had any success with fixing these?
Car: 84 z-28, 85 iroc front/rear
Engine: 355, dart heads, hooker headers
Transmission: built 700r4, 3000rpm stall convrtr
Axle/Gears: 9 bolt Moser, 3.27 posi
the problem isnt that they leak, the problem is your driving in the rain, get second car, that'll solve your problems.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
do you ever take the t-tops off?? if you never do, then i say silicone that bastard shut.. just do a clean job and no one will ever notice the silicone..
1 Post
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
No way, the whole reason I bought a bird over many other sports cars was for the T-Tops. I drove mine only on nice days so I don't get what the big deal is- not like these things are safe in the rain.
Axle/Gears: 3.08
Relating to driving in the rain: checkout Goodyear Eagle F1 GS/D3s. I upgraded wheels/tires from the stock rims/Goodyear Eagle GTII(worst tire ever) to 17" Rims and the GS/D3s, best wet and dry traction I have ever experience in any car, quite impressive for 8.5" w. Sorry know thats unrelated to T-Tops but it seems that with good tires wet traction really doesn't have to be an issue.
Car: 84 bird
no doubt, I don't have a garage space for the bird and as luck wood have it I'm using the bird as my daily driver. sitting on wet seats and smelling that nasty wet dog smell gets old quick. I have to work on my car on weekends and nights since I'm daily driving it. i'm reasonably intelligent, and heck I've worked as an auto mechanic for the last 14 years of my life and I can see no reason why these &^%%&^^ t-tops are still leaking!!!!!!!
like i said I followed the FAQ on this site and well.... i have plenty of car repair experience, including body work and water leaks etc etc. I have the feeling I'm overlooking something really really simple or these things just leak no matter what!!! anywho... it would be nice to sit on a dry seat
Car: 1984 z28 ho
Engine: L69
Transmission: 700-r4
i solved all my ttop leaking problem when i took the ttop its self apart and reglued (silicone) the latch back to the glass. it never was the weather stripping. when you take it apart you will see where you need to apply new selent and dont skimp, thats why they leaked to begin with. hope this is helpfull.
ure not talking about the handle are you. and in response to that adhesive weatherstripping, do you have any pics? id love to see because i think thats all i need because my seals are in awesome condition.
Engine: LT1; None
Got a pic of the piece you are talking about, so I am clear?
Car: 1984 z28 ho
Engine: L69
i dont have any pictuers. take off the plastic trim, take off the weather stripping and you will see the entire latch mechanism is glued onto the glass. this is where i found mine to be leaking.
T-tops a mistake?? No way. Give me t-tops over a sunroof anyday. Verts are alittle different...and I like both. However I agree with the guy above...t-tops are what sold me on my car.
My center piece is rusted, im sure the channels are rusted, and i have tears in the weather stripping that someone rtv'd shut. However mine dont seem to leak. Only a tiny bit towards the back that gets the rear seat/floor area alittle damp during a hard rain.
I have new weatherstripping, a new center section, and means to repair any rust on hand. Its going to be my winter project.
Im wondering if chassis flex causes weird leaks. Ive seen some guys with weird gaps in their tops from side to side, almost like at some point the chassis flexed due to an accident or something. A small little fender bender is all it takes sometimes. haha.
Justin
Justin
Car: 84 bird
Engine: 4++,350 & 305 CIs
Dont laugh but if mine has to sit out in the rain i put black electrical tape on every seam it works great and wont leave sticky crap on the car .. I carry 4 rolls at all times and yes I have redone my seals also
Car: 84 bird
OK I had some more time to mess with this thing.
Coincounter THANK YOU some of the water is indeed coming from where you said.
The rest of the leak I did something wrong - I didn't glue my weatherstrip in what was happening is in the center near the Tbar water is coming in there and getting in under the weatherstrip - Out of pure frustration I also ( and I'm not sure if its was necessary or not ) took some RTV and ghetto rigged the crapola out of it. under the Tbar thing in the center at the front and rear the weather strips do not touch. I don't know if factory ones do or not. PO had installed weatherstrip on my ride. Anyhow, I filled the gap between the weatherstrips under the center bar and glued my weatherstrip to the body and holy cow I don't believe it!!! no more water on my seat!!! Doing the no more water on my seat dance!!! ya'll don't have that dancing banana in the smilies......
i cant imagine that if you have redone all the seals correctly that the car would still leak, water can only fit through a space larger than its molecules, so maybe your seals just arent tight enough, or maybe you missed something. also my 84z-28 had its seals professionally replaced by its previous owner, she doesnt leak a drop in the rain. then again ive only driven her twice in the rain.
Car: 91 camaro RS
Engine: v8 350 5.7 OHV
Re: what is the deal with T-tops!!!
I have a t top and had the same problem i just tighten the bolts and problem sloved..... see how it works out with you
Car: '91 Firebird (blown apart)
Engine: *cough*BOAT ANCHOR*cough*
Transmission: Slushbox
Car: 92 Firebird
Transmission: auto, unfortunately
I too discovered that the t-tops leak in my Firebird not much though which is good. I see exactally how and where mine are leaking and that issue will be resolved tomorrow with some new seals from the Easter Bunny
This rea is known to leak if not sealed correctly. Did you bridge the gap between the top rail and the A pillar rail? There is a channel that runs from the center of the car to the edge. There is about a 1 inch gap and then another channel that runs from the bottom of the A pillar to the top of the A. You need to use windshield rope caulk and bridge that gap. That seals the area from leaking. Here's a pic of the B pillar channel.
Car: '84 Trans Am
Engine: 305 -- 150hp
I had the simplest solution ever to this problem. Go to your local hardware and buy a tube of Seal All, or Leak Stopper, or whatever it's called. It's a liquid in the tube, but becomes a hard plastic once applied and dried.
This $3 tube sealed a gas leak in my old truck line and sealed my T-Tops. They leak NO MORE.
For the T-Tops, I found the channel that the rain runs down, found the cracks in the old rubber and applied the Seal All. Problem solved. It dries clear too, so it's hard to see if you're worried about looks.
Car: '84 Trans Am
Here are some photos of the Seal All fix. It looks worse in these photos than in real life. Probably because the flash is so close.
Car: '84 Trans Am
I applied the Seal All last spring and it was leak free all summer. This year, it started leaking again (a little) around July, so I just re-applied a little bit last month. Honestly, I haven't had it in the rain or washed it since re-application.
Thirdgen89GTA
11-26-2015 11:04 PM
LT1Formula
10-08-2015 08:34 PM
Dragonsys
09-25-2015 03:51 PM
