T-Top gasket
Old 08-28-2006 | 07:19 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
T-Top gasket
I think I found another leak in my t-tops today. There is a gasket under the plastic part of my t-tops, shown in pic. It is all dry rotted and there are peices missing. Is this a replaceable gasket? Thanks for any help.
Old 08-28-2006 | 07:54 PM
Frank89IROC's Avatar
This is the soft weatherstripping, click on the line below::
Camaro/Firebird 82-92 "Cars & Concepts" T-Top Side Rail Weatherstripping
& this is the hard piece above that:
Camaro/Firebird 82-92 New GM T-Top Seal Strip L - 8353-WS
Old 08-28-2006 | 07:57 PM
grimmcs's Avatar
Car: 91 Camaro
Thanks I didnt know what it was called, so it was making finding it a little hard. Thanks again
Old 08-28-2006 | 10:04 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Frank, do you know how to get that hard piece off of the t-top? I removed the screws that I could find, but the piece isn't budging. If I knew how many screws there were, I'd know if I missed some, or if the thing is just stuck fast from being on there for so long, or because someone used adhesive on it at some point.
Old 08-28-2006 | 10:24 PM
It's been several years since I replaced them, but I think they were glued on. The new one attaches like the moulding on the doors, you peel off the tape & it glues on. I'm 90% sure
The one from HAWKS is actually plastic, unlike the original, which is a hard rubber.
Old 08-28-2006 | 10:51 PM
Bull's Avatar
Engine: LT1; None
Hmm, ok, that's good to know. I was pulling on it pretty hard, but it didn't seem to want to go anywhere. I'll triple-check for any missed screws, then I guess I'll just have to pull and pry till it lets go!
Old 08-28-2006 | 11:23 PM
Did you remove the weatherstripping? If there were any screws, they would have been hidden under the weatherstripping.
Old 08-28-2006 | 11:29 PM
Bull's Avatar
Engine: LT1; None
Yep, I did remove the spongy weatherstripping first.
Old 08-28-2006 | 11:37 PM
there may be a couple of screws under the bracket that the T-top weatherstripping slids on to. See if you can remove that bracket. I pretty much took everything apart as I also replaced the lock cylinders at the same time. Again, it was some time ago and my memory isn't as good as it use to be.
Old 08-28-2006 | 11:40 PM
Bull's Avatar
Engine: LT1; None
Thanks for the help and suggestions Frank, it is very much appreciated.
The t-tops I am working on are actually my old Lexan set, that I no longer use on my Formula. I am using them as a test, seeing how to properly remove the seals so that I can then do the job on my glass tops without damaging anything!
Old 08-28-2006 | 11:53 PM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
Im pretty sure there are screws there, i removed them a wile ago so i dont know where the screws are but i do remeber them being there. And where can i find a set of lexan t -tops for my car?
sheachopper
07-31-2019 12:27 PM
Jorlain
Exterior Parts Wanted
06-30-2017 12:04 AM
1Aauto
Sponsored Vendors
01-15-2016 07:26 AM
Thirdgen89GTA
11-27-2015 12:04 AM
meeklay812
10-01-2015 04:46 PM
Quick Reply: T-Top gasket
