Weight?
1 Post
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
Weight?
Does anyone have an idea of how much my car weighs? its a 87 IROC I have powersteering and t-tops. Plus everything in my info at the bottom.
1 Post
Car: 1987 IROC
o ok thanks your a big help. i just bought one of those Gtech Pro performance meter. I need a close weight for it
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Click Here and Scroll Down:
https://www.thirdgen.org/tech-data
Add the weight of the Z28 curb weight and all the accessories that your cars has. Once you do that, subtract about 25lbs and you are close enough for a G-Tech.
Good luck.
Good luck.
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
why did you get one of those? the only thing i could see working well on it is the geforce cmon now sequential shift lights horsepower and torque all from reading your battery voltage from your cigarrette lighter...
Originally Posted by Douchermann
How about for a 1990 formula 350, I can't find weights on it in the tech data.
Last edited by Jekyll & Hyde; 07-31-2006 at 07:19 AM. Reason: Automerged Doublepost
Damon
09-26-2015 04:29 PM
