Fender skirt clips - Part # or size?
Missing a few of these on my fender skirts and wanted to replace these.
The clips that are still there have been pulled before and are quite worn. I found a spot on the net that sells replacement clips. Just need to know size and/or part #. Thanks.
I tried looking at napaonline.com and that part number doesn't come up.
I'm replacing my power antenna and I noticed that the clips are worn or missing. Is there a GM part # for these?
That part # does come back as a retainer (for many part besides the fender skirts) However, when I searched the GM database, I show that it is for 93-02 models.
Can I be sure that these are the correct retainers for my '89?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The thirdgen ones had the annoying little plastic peg to push in the center. The part number I gave uses a philips screw.
If you want the part number for the thirdgen ones, I can look it up in the catalog later.
I found the picture of the part you list on Northland Fasteners site. Looks like this will work.
Where can I find a listing of all the fateners (with part numbers) that are used for my vehicel?
Looks like your part # would be reusable more often than the original part.
Engine: 383 Carb
Transmission: 4L60
82-90 cars use 20664092
91-92 cars use a bolt, 11513942
For part numbers, try to get your hands on a GM Parts & Illustration Catalog for your car.
toronto formula
11-10-2015 06:17 AM
knight72
08-10-2015 09:32 PM
