Front sub frame
Car: 91 rs
Front sub frame
Has any one ever changed one out?
I have a 91 RS that need the front sub frame changed out on ..
i know i have to strip it down.(motor,trany,lines,ext.)
is it all dolted in or is some of it welded ?
any short cuts ?
Thanks,
Chris
any short cuts ?
Thanks,
Chris
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The front subframe is entirely welded in. If you need to change the subframe, you're better off getting another car.
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
the only easy way to do this is to clip the car, im using the term easy very loosely too. ive clipped a few cars and it is a lot of work. it invloves drilling out all the spot welds that connect the front of the car to the rest of the car.the cut the rockers and a pillars. there are many measurments that need to be taken in order to ensure that it goes together the proper way. then the a pillars and rockers need to be sectioned back together. im not going into to much detail on the whole process because this post would b crazy long. ill include pictures of an integra i did a right hand drive conversion on, the front clip is from japan. the first picture is a before, second and third are during. notice in the third that only the inner section of the rockers and a pillars is welded up and the outer portion hasnt been sectioned in yet.
matt
matt
Car: 91 rs
thanks guys,
the 91 has a lot of value to me.and i am going to do it.and now i have another 91 im restoring for my wife ..so i have my summer cut out for me.
1992 Trans Am
05-10-2023 07:19 PM
