hatch alignment tech article
Car: 1988 trans am GTA
Engine: 350 tpi
i got a new spoiler and i decided to finnaly align my trunk and repaint it and a while ago i saw the tech article for removing and aligning it but now it seems to be gone! any one know where it ran off too?
http://web.archive.org/web/200406061...tchalign.shtml
I also know you can do it at the hinges which connect to the body. He said he just loosened the 4 bolts up there, loosened the struts, and he was able to re-align it that way. I haven't tried it yet (going to try it tonight)
Car: 1990 Firebird Formula
Engine: 305 tbi
I did most of that repair. I forgot to tape off for the reinstall, which just made it a little harder to align. The other issue I ran in to is after you remove all the goo from the seal, I forgot to remove the spot on each sidewhere the plastic channel guides set. If you do not remove these two side spots it will be a hair off on reinstall. I did not remove them since they are had as a rock. I used a bar stool with a thick pad to hold the hatch up. Once the spoiler, and metal peice are removed the hatch is pretty light.
I just finished up aligning the hatch using the second method I mentioned. It's still not fully aligned, but it's less than 1/8th of an inch. I'll have to do the first method sometime during the week to get it completely flush.
Engine: 350 tpi
im removing the trunk lid for paint but it is wayyyy out of wack right now and i was just seeing if ther was a good safe way to remove that peice and how to put it back on. thanks for the help!
formula00ra
Interior Parts Wanted
09-28-2015 11:50 AM
