how to open rear hatch
how can i get my rear hatch open on a parts car i bought today!!!
i have no keys, and its a low option car(no cruise even) without the button on the console to open the hatch. could i just drill out the key hole?
1 Post
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
First, try your key ( I assume you have another third gen). Than screwdriver it. If that doesn't work I would probably drill it out. However, a screwdriver (flat head) can work miracles if used right!
Good luck.
I hope you are not going to be using the locking mechanism anywhere else.
Good luck.
Car: 91 Camaro RS
Engine: TBI
if you can pop the cylinder out of it and yank teh inners out you can usally get a small screwdriver into the slot where the rod comes out, pop right open, its been a few years since i've done it but i know it was little to no damage to teh car
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
or you can go through the light in the interior. Pop out the light and i think you have to remove a 10mm bolt that connects the lock to the hatch release (hatch pull down feature equipped car??) Then once that part is off you can turn the thing with a screwdriver. Did it many times n junkyard cars
Car: 1982 Trans Am
Engine: SBC 400
Axle/Gears: 9 Bolt 2.77
I come across this all the time at junkyards, it's a PITA but if you can crawl into the back seat and remove the rear hatch panel to get to the locking mech, you can stick a flathead screwdriver in the latch to move it over. Have someone outside to pull up on it when you do...I guess if worst comes to wost and you don't need the rear taillight section, bust out the lock. You can stick a screwdriver in from the outside.
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Done this on occasion with my own. Just pop out the cargo light, look inside, a slot is visible on the mechanism. Use a long flathead screwdriver in the slot to operate the mechanism from the cargo bay.
Street Lethal
04-30-2019 12:14 PM
