Trouble getting bumper off
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
I've been trying to take my bumper off and I have found that on these screws below, there are no tops to use a wrench or socket to get them off, they are bare. The only real solution I see is using a hammer unless someone else can think of something. Sorry I couldnt get a very good pic of the top where there isnt anything to screw off.
http://i33.photobucket.com/albums/d6...Picture357.jpg
http://i33.photobucket.com/albums/d6...Picture361.jpg
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
Car: To many to list
Those are the studs that were holding it to the body correct?If so then you already took the nuts off.The rubber nose/bumper pulls off of those studs.The steel bumper and the rubber nose will seperate.The steel plate with tose studs is also attached to the hood plate(where the hood latch is)HTH
Car: 1985 Camaro
Engine: 2.8L V6
Try taking a picture further away from the object, it looks like your camera can't focus that close to the bumper.
