Floor Pans ... Hard to Replace?
Old 04-23-2006, 03:38 PM
Mythos's Avatar
Car: 1991 Pontiac Trans Am
Engine: LB9 305 V8
Transmission: THM 700R4
Axle/Gears: 2.73 Limited Slip
Well i'm thinking my T/A is going to be needing floor pans and I noticed that Hawks does have them available. I've done bodywork, but I have never replaced the floor pans on a car, with the proper equipmnet is it very hard ?
Old 04-23-2006, 03:45 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
With the proper equipment,no.Once the interior is stripped you can lay the new floor pans in place and trace around them with a marker,take them back out.Cut out 1" below the marker line,as well as remove any floor bracing that will need to be reused.Drill 5/16" holes around the top edges of the new floor pans every inch or so.Ley the floors in place,line them up,start welding.It would also be helpful to sheetmetal screw them in place once you have the new pans lined up to hold them tightly during welding.Replace any previously removed bracing and weld back in as well.Seam seal and paint/undercoat.
Derick15
Members Camaros
08-20-2015 10:19 AM
MY87LT
08-17-2015 08:43 AM
Ginamariegault
Brakes
08-10-2015 08:33 AM
Amillionoh7
08-07-2015 01:24 PM
Quick Reply: Floor Pans ... Hard to Replace?
