Rear window defroster removal
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Remove the plastic cover for the gauges. The defrost has 2x 9/32" holding it on from the backside
Likely have to drop the steering column and unscrew the dash pad to get the trim piece off, atleast I had to
Car: 89 formula 350
Transmission: Stock 700r4
Mine only had a small set of wires comeing through the back, and it was stuck on my double sided tape. I am confused
You have to drop the column to get the radio Trim off?
Last edited by ponykiller1992; 04-03-2006 at 10:00 AM. Reason: Automerged Doublepost
Car: 91 Trans Am
Engine: LSA
The trim surrounding the gauges also holds the defrost button on 89's
It just so happens to be difficult to remove with the column set
Has absolutely nothing to do with the radio trim
Later models had a removable switch panel and still had the buttons screwed to the back, so you didnt have to remove the whole gauge trim unit
If yours were taped to the back of the radio trim then you have a serious hackjob firebird. Not even close to where the button should go
Car: 91 Trans Am
Engine: LSA
eBay Motors: 1982-1992 Firebird Dash Gauge Bezel Trim Interior (item 8042339038 end time Apr-28-06 07:55:01 PDT)
This is the trim where it should be
Its deleted for this one, but you can see how its attached to the back
Eric-86sc
04-03-2016 04:52 PM
