I need help with ground effects
Car: 1989 IrocZ
Engine: 5.0 TPI
Axle/Gears: 3.43 rear disc brakes
i really need to know how to get off the iroc or Z28 sym down at the bottom of the fender/door are there clips, can i just pop it off? i dont want to mess them up but i'm sanding the body preping for a paint job i know how to remove all the bolt other then them
Car: 1989 IrocZ
Engine: 5.0 TPI
no you see to get the ground effect off i need to take out the bolts that hold on to the ground effect off first. I have been told there is 2 bolts under the iroc sym. ,that i need to get to and i've heard that there are clips and i heard that there are no clips.
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
I was able to carefully pry mine out without breaking it, it was glued in with some sort of adhesive. There are 2 screws behind it that hold the gfx tight to the fender.
Car: 82 Z
Engine: 350 carb'd
Transmission: th-350
Axle/Gears: 3.08 posi
yea do it very carefully
when replaced both my fenders, one broke and the other one is stayed together
Car: 1989 IrocZ
Engine: 5.0 TPI
got the ground effect off the back plastic holders broke off one was already broke but the thing that thrown be for a loop is 3 bolts hold on und were the door sets that i see the bottom but the head is covered by the ground effect riped the out messed it up a little bit how do you get them off right i don't know
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Commas, periods, and proper sentence format will help me figure out what you are trying to convey. I have read over your post 10 times and I am dumb founded by your post, please restate the question?
Damon
09-26-2015 04:29 PM
